Use CLI to verify your installed software. It is important to verify your software version before you place a device into a production environment.
enable
show software detail
The following is an example of the output of the show software detail command.
Switch:1#show software detail ================================================================================ software releases in /intflash/release/ ================================================================================ VSPSwitch.X.X.X.X_GA MP UBOOT int009 KERNEL 2.6.32_int29 ROOTFS 2.6.32_int29 APPFS VSPSwitch.X.X.X.X_GA AVAILABLE ENCRYPTION MODULES No Modules Added VSPSwitch.X.X.X.X_GA (Backup Release) MP UBOOT int009 KERNEL 2.6.32_int29 ROOTFS 2.6.32_int29 APPFS VSPSwitch.X.X.X.X_GA AVAILABLE ENCRYPTION MODULES No Modules Added VSPSwitch.X.X.X.X_GA (Primary Release) MP UBOOT int009 KERNEL 2.6.32_int29 ROOTFS 2.6.32_int29 APPFS VSPSwitch.X.X.X.X_GA AVAILABLE ENCRYPTION MODULES No Modules Added -------------------------------------------------------------------------------- Auto Commit : enabled Commit Timeout : 10 minutes
